Anyone seen rivet nuts other than Metric or SAE?
Would like to use a 5/16th fine for the bolt attaching the front stand to the mudguard on a new alloy front mudguard.
Will make up an alloy pad with glue but want the main bolt to go into a rivet nut.
Haven’t found any fine threaded rivet nuts at all.
Rivet Nuts
wade.edwards
Re: Rivet Nuts
Try aircraft suppliers which is generally AN threads.Metric in Europe. AJS/Matchless have 4 small rivets holding the Captive nut and that looks OK. Nev
garycullen
Re: Rivet Nuts
I googled imperial river nuts uk and got a lot of hits.
One supplier had UNC and UNF.
There was also a BSF supplier….
Options in steel and SS as well.
Gary Cullen
Forrest Hill
Auckland
Antipodes
1946 VB600 rigid Tele
1933 Austin 10
Forrest Hill
Auckland
Antipodes
1933 Austin 10
wade.edwards
Re: Rivet Nuts
Thanks Nev and Gary.
Successful search results are often dependent on the key search words.
Re: Rivet Nuts
That could possibly make a mess when undoing later if the threads get rusted.
Have you had a look at how the stays are done on a VCH Ariel with their alloy guards? Handles allow the Bike to be Hauled out of the Mud, but are also useful when loading it into a Van or trailer. Nev
