Hello Hello,
For the rebuild of a 1929 500 OHV I am searching for the rocker levers, partnumbers:
A6/432 and A6/433
If it would be available in a joblot than that would be of interest aswell.
Best regards,
Rik
1929 Rocker levers
Re: 1929 Rocker levers
Sven down on the isle of wight is getting prices for having some made, he has been looking for a long time, as have I. Sven posted in the sheval this latest copy in a last ditch attempt before going for new ones. We will get them on the road! Don't give up. Jim
IF you are stuck the Later ones will fit you just have 2 Possible adjustments for each valve. Valve stem length stays the same and all will work ok.
tony.barnett
I thought the same, particularly for a plate supported rocker set up like a 29. Make some spacers and fit later rockers.nevhunter wrote: Mon May 04, 2026 6:28 am IF you are stuck the Later ones will fit you just have 2 Possible adjustments for each valve. Valve stem length stays the same and all will work ok.
KOBI
Velocette MAC, KSS Mk1
You haven't permanently Altered anything and enables setting up the valve Lifter More accurately. Nev
Users browsing this forum: roland robinson and 1 guest
