Hello,
I am a member for over 30 years and owner of several Ariel motorcycles, I'm having trouble with the kickstarter on Burman CP 1 Gearbox
Kickstarter is very difficult to activate. When I declutch it is free !
I can't start the engine.
I'have completely disassembled the gearbox, and everything seems fine...
Does anyone have any ideas?
Thanks in advance,
Eric From France
P.S. 1939 Ariel 350 Red Hunter, Engine BH148, Frame XG9436, Gearbox CP1
Burman CP1 Gearbox kickstarter
- eric.delegrange
Re: Burman CP1 Gearbox kickstarter
When you say it is difficult to activate, could you explain a little more about what happens or what does not happen. Was the bike OK before this or have you just built it?
Moved to 4-stroke...
Administrator
webmaster@arielownersmcc.com
- eric.delegrange
Hi Roger
Thanks you for your consideration
The kicstarter is nearly impossible to go down, but it go down, but it is very hard !
Thanks in advance,
Eric From France
Thanks in advance,
Eric From France
If you take the spark plug out, can you turn the engine by turning the rear wheel?
- eric.delegrange
Hi Simon
No problem to turn engine with the rear wheel,
The engine start et run normaly with roller.
Thanks in advance,
Eric From France
Thanks in advance,
Eric From France
Chris Sealy
If the engine is good, and the gearbox also; then I would inspect the clutch. Maybe a worn bearing is allowing the clutch to contact the casing, causing friction.
