4g mkII
Re: 4g mkII
As far as I can tell it has it's original engine and gearbox,
Re: 4g mkII
The gearbox should be a GB7 with an appropriate date code, probably K54
to K55.
It's still possible the original quadrant and ratchet pinion have been replaced
with the far more common but incorrect parts. It'll be worth checking the next
time you have the gearbox outer cover off.
to K55.
Chris Sealy
Re: 4g mkII
I've just checked my GB7 gearbox kickstart. If I bring any piston up on compression, then allow the lever to return to the fully up position. Then push it all the way down I get just three pistons up to and over compression. Try yours Ken.
Re: 4g mkII
Will do, but not tonight,
Chris Sealy
Re: 4g mkII
True Dave. My thinking is; If my very easy to start squariel is 3 compression strokes, and Ken's is 5 or 2, we may be on to something.
Re: 4g mkII
Just been out on it, and given it a bit of stick on the dual carriageway, it runs well, it has 3 compression strokes on the kick start, need to rethink the external oil filter, it's a sod to change.
It backfires a bit on the overrun, plug colour looks ok.
Re: 4g mkII
Lean at idle or airleak at exhaust to Head join. Nev
Re: 4g mkII
Where's your filter Ken?ken-drink wrote: Fri Jan 30, 2026 3:28 pm Just been out on it, and given it a bit of stick on the dual carriageway, it runs well, it has 3 compression strokes on the kick start, need to rethink the external oil filter, it's a sod to change.
Re: 4g mkII
It's under the gear box,
Users browsing this forum: Bing [Bot] and 5 guests
