So, 2000 miles in (actually 3000 miles for the bores and pistons as they were reused in this build) inexplicably seized the left-side piston 'big time'. This has all been relatively light use, not much above 60 for any length of time although there have been a couple of motorway trips at 55-60.
However, this was the first attempt at anything sustained at over 60-65 for any length of time. It happened after about 25 motorway miles of 65-70. Very ironically, just as I was marvelling at the way the bike was romping along with the throttle barely open.
Up to this point the engine's had a set of JP pistons, fitted as part of a major rebuild with much of the work done by SRM. SRM didn't want anything to do with the JPs and warned me they'd seize as they'd had a series of failures with them even when they'd increased the bore clearance. And after 416 miles (all very careful and controlled) they were proved right when I suddenly noticed some metal flakes in the oil tank gauze and a top-end strip showed the right-side piston had 'nipped up' exactly where SRM said it would (very top of the skirt just under the oil ring).
As that was a 'nip' I cleaned it up and put everything back together again, and that was OK for another 400-odd running-in miles before 'other issues' stopped that iteration.
(See viewtopic.php?t=14293)
My 'cleaning up' shows fairly clearly in the pics, that piston was OK this time but the other one (previously undamaged) decided to quit.
Concluded the fault was with the JPs, honed ('glaze busted') the bores, fitted a pair of new Wassell/Hepolites, oil and filter change, everything back together, a first fairly gentle 45-mile trundle was trouble free so a day or two later off for something longer. 15 miles in, after a few minutes cruising at 45-50 on a very light throttle, suddenly no engine and a brief squeak from the back tyre.
I assume it's seized the pistons again - which suggests that it's the bores that are the problem (despite having been done by experts with lots of experience with this type of engine) and I need to exonerate the JPs. (In the pics, the front and back of the 'good' JP piston have a polished look - it's not a trick of the light - which might suggest running 'tight'. I'd expect the same matt appearance all round the skirt, but I'm not familiar with how JPs look in use).
I haven't got the time (or inclination) to do anything with the bike at the moment, and anyway I can't see an easy fix as the bores surely can't be very far out and having spent several hours combing through original Hepolite catalogues and looking at the specs from current manufacturers (JP/Wasell/IMD) I can find enough different bore specs to amount to effectively a thou difference in size so I can see possibilities for debate over exactly how much correction mine might need. (I did check the piston/bore clearance with a feeler gauge and it seemed to be as per the spec on the instructions that came with the pistons but maybe there's an art to it that I haven't got.)
(And to think I've avoided Square Four ownership because they're just too costly and troublesome!
