Mick D wrote: Mon May 05, 2025 1:56 pm Hi
They are the same size top and bottom. When you get the new bushes find a socket just bigger than the bush OD and a nut and bolt long enough to pass through the socket and bush. Thread the bolt through the bush and socket and tighten the bolt, the bush will be withdrawn into the socket. Reverse the procedure to fit the new bush, a bit of tyre soap or red rubber grease will help the bush slide in.
Video here: https://www.youtube.com/watch?v=Je2Xzb7-BFE
Thank you Mick
With your help managed to instal the bushes.. thank you
