Wanted DU42 Headlamp Reflector
ClintR
Post by ClintR »
Hello:
Searching for a used DU42 headlamp reflector for the bulb holder type that mounts on the back with attaching wire spring: Pt Nr 515140 + 516145, to use with a blackout mask. Does not matter much the condition of the silvering of the reflector.
Doc
Re: Wanted DU42 Headlamp Reflector
Post by JohnnyBeckett »
hi you can give Russell Motors a they do Ariel war Department and BSA if not you can try looking Ebay under Ariel parts
515140 is a light unit or reflector for the DU142 or 8". 516145 is the one you want, the modern Indian replacements are a complete light unit, ie reflector, glass and bulb holders but do not seem to be available at the moment.
ClintR
Post by ClintR »
Roger:
Thanks; I thought it was the 517145 unit, but I found a site that listed as 515140+516145; I did not what that + sign meant, so I included it in my forum request😊.
Doc
ClintR
Post by ClintR »
Sorry:
Big fingers! 516145 and “did not know” what that meant!
ClintR
Re: Found DU42 Headlamp Reflector
Post by ClintR »
Hello
I found one!
Doc
