Ariel VB - a persistent oil leak
SteveShone
Re: Ariel VB - a persistent oil leak
Post by SteveShone »
Mark, Julian - thanks for the tips. Every little helps. 👍
Ive been out shooting all day today so have still to seek out the hidden magneto bolt 🔎 I dont expect the new seals will arrive until next week now.
Steve
MarkO
Post by MarkO »
You'll know if the hidden bolt is there when you remove the obvious 3 screws and the mag. won't budge!
Whilst the mag is off, I'd look to clean the slip ring, earth, check the HT mag end - bitter experience! - and try and get some grease into the drive end bearing.
SteveShone
All being taken care of, Mark :-)
Whilst Im still awaiting delivery of the seals from Draganfly I thought Id take the opportunity this afternoon to give the head a decoke and fit the new stainless steel head bolts I got from ACME a few weeks ago. I was somewhat annoyed to find that I had been sent BSCY thread bolts and not the BSF ones needed. Had hoped to use the bike on a club run on Wednesday (fine weather promised at last) - now that looks unlikely unless I refit the old studs for the time being and waste a head gasket.
Ive emailed Clay and await his response and lead time for the correct bolts.
Steve (the rain may have stopped but there's always something to spoil plans!)
Don't use SS bolts with an iron head, the rate of thermal expansion doesn't match the head.
SteveShone
It's an ali 9 stud head, Roger.
Steve
Pete.Silson
Post by Pete.Silson »
If you ordered SKU2396 from Acme, these are the bolt set for the iron head VB (7x 5/16 x 2″ CEI plus 1x tdc plug)...
...and I agree with Roger, stainless bolts are not a good idea for screwing into cast iron cylinder blocks.
Pete
SteveShone
No, it was a set of 9 head bolts - the tdc plug I made myself.
Steve
Ally heads originally used studs and nuts, not bolts
SteveShone
Yes, I know, Roger. With bolts, it's possible to remove the head if needs be without disturbing the tank mountings. If Clay can't replace what he's supplied with BSCY items, I'll probably make my own replacement studs with nuts - in stainless 😉
Steve
Users browsing this forum: ChrisG and 13 guests
