Hello all,
Does anybody fit the insulating washers under the valve spring holder on a single not having fitted them before I just wonder are they worth while and if they are, where do I either get them or the material to make them from Thanks Clive.
Insulating washers under valve springs
Re: Insulating washers under valve springs
Yes, I always use them and for no better reason than that's what Ariel did.
Valve spring cup washer, Halite, 580-34 and seemingly available from
Draganfly and possibly others too such as the spares scheme.
Got mine from Drags when ordering other parts. Although the Halite washers are cheap the postage for a pair of washers is not
Dennis
Dennis
1955 VH500 alloy head
Thanks both of you for the replies I will get some when I am in that direction Clive.
