Page 1 of 2
Wanted parts for Black Ariel ‘27 or 28
Posted: Fri Feb 11, 2022 3:01 am
by MGriffin
Any Fork Parts - Found
Front Chain Cover - Found
Front Hub - Found
Rear Hub - Found
Clutch (any of the parts) - Found
Q Gearbox or parts - found
but happy to consider spares
Magneto - Found
B&B Carburettor
Mudguard stays
Handle Bar - still searching
Seat frame complete or parts - still searching
Michael
Re: Wanted parts for Black Ariel ‘27 or 28
Posted: Fri Feb 11, 2022 9:47 am
by tony.barnett
Be aware that some 27 and 28 parts look the same, but are very different - for example the forks are much narrower on the 27, and likewise the front hub. Interchangeable as an assembly I'd think, but not as parts.
Posted: Sat Feb 12, 2022 2:12 pm
by Karol Burger
I sent you a message
Posted: Sun Feb 13, 2022 7:51 pm
by MGriffin
tony.barnett wrote: ↑Fri Feb 11, 2022 9:47 am
Thanks Tony yes i’m learning these things.
Karol is also being veru helpful and i thank him for that.
M.
Posted: Sun Feb 27, 2022 10:46 pm
by MGriffin
Still looking for a Rear Hub if such a thing still exists.
refer to picture
M.
Posted: Sun Feb 27, 2022 11:28 pm
by Vincent.vanGinneke
apart from the teeth, whats wrong with this one ? it looks o.k.
Karol has new sprockets with a 'step' in it that can be used on these hubs after grinding the old teeth off.
like this :
Posted: Tue Mar 01, 2022 12:25 am
by MGriffin
Vincent.vanGinneke wrote: ↑Sun Feb 27, 2022 11:28 pm
like this :
rear wheel sprocket fitting (6).jpgrear wheel sprocket fitting (5).jpgrear wheel sprocket fitting (4).jpgrear wheel sprocket (1).jpeg
I wasnt of the impression that the pictured rear hub above was available to buy.
I thought that hub which is on the Klub Slovakia Webpage was being used to demonstrate Karol’s new rear sprockets and how they are installed. Its also missing the RH spoke anchor hat.
I shall have to ask. Thanks Vincent.
Michael
Posted: Tue Mar 01, 2022 8:29 am
When lacing the wheels on these Black Ariels the anchor hat needs to be loose as otherwise you cannot get the spokes in.
Later Ariel used a 'keyhole' there + a fixed anchor hat.
On the later ones you can hook in the spokes without the need to start with a separate hat with the spokes hung in it.
Posted: Tue Mar 01, 2022 8:51 am
by MGriffin
Vincent.vanGinneke wrote: ↑Tue Mar 01, 2022 8:29 am
Thanks for explaining that Vincent.
MG.
Posted: Wed Mar 02, 2022 8:58 pm
by MGriffin
The B&B Carburettor I’m looking for.
