Wanted parts for Black Ariel ‘27 or 28
Any Fork Parts - Found
Front Chain Cover - Found
Front Hub - Found
Rear Hub - Found
Clutch (any of the parts) - Found
Q Gearbox or parts - found but happy to consider spares
Magneto - Found
B&B Carburettor
Mudguard stays
Handle Bar - still searching
Seat frame complete or parts - still searching
Thanks
Michael
Front Hub - Found
Rear Hub - Found
Magneto - Found
B&B Carburettor
Mudguard stays
Thanks
Michael
Michael.
28 Model A
28 Model C
48 Red Hunter
Michael.
28 Model A
28 Model C
48 Red Hunter
Re: Wanted parts for Black Ariel ‘27 or 28
Be aware that some 27 and 28 parts look the same, but are very different - for example the forks are much narrower on the 27, and likewise the front hub. Interchangeable as an assembly I'd think, but not as parts.
KOBI
Swindon Branch Secretary
Velocette MAC, KSS Mk1
- Karol Burger
I sent you a message
Thanks Tony yes i’m learning these things.tony.barnett wrote: ↑Fri Feb 11, 2022 9:47 am Be aware that some 27 and 28 parts look the same, but are very different - for example the forks are much narrower on the 27, and likewise the front hub. Interchangeable as an assembly I'd think, but not as parts.
Karol is also being veru helpful and i thank him for that.
M.
Michael.
28 Model A
28 Model C
48 Red Hunter
Michael.
28 Model A
28 Model C
48 Red Hunter
Still looking for a Rear Hub if such a thing still exists.
refer to picture
M.
refer to picture
M.
Michael.
28 Model A
28 Model C
48 Red Hunter
Michael.
28 Model A
28 Model C
48 Red Hunter
apart from the teeth, whats wrong with this one ? it looks o.k.
Karol has new sprockets with a 'step' in it that can be used on these hubs after grinding the old teeth off.
like this :
like this :
I wasnt of the impression that the pictured rear hub above was available to buy.Vincent.vanGinneke wrote: ↑Sun Feb 27, 2022 11:28 pm apart from the teeth, whats wrong with this one ? it looks o.k.
like this :
rear wheel sprocket fitting (6).jpgrear wheel sprocket fitting (5).jpgrear wheel sprocket fitting (4).jpgrear wheel sprocket (1).jpeg
I thought that hub which is on the Klub Slovakia Webpage was being used to demonstrate Karol’s new rear sprockets and how they are installed. Its also missing the RH spoke anchor hat.
I shall have to ask. Thanks Vincent.
Michael
Michael.
28 Model A
28 Model C
48 Red Hunter
Michael.
28 Model A
28 Model C
48 Red Hunter
When lacing the wheels on these Black Ariels the anchor hat needs to be loose as otherwise you cannot get the spokes in.
Later Ariel used a 'keyhole' there + a fixed anchor hat.
On the later ones you can hook in the spokes without the need to start with a separate hat with the spokes hung in it.
Thanks for explaining that Vincent.Vincent.vanGinneke wrote: ↑Tue Mar 01, 2022 8:29 am When lacing the wheels on these Black Ariels the anchor hat needs to be loose as otherwise you cannot get the spokes in.
MG.
Michael.
28 Model A
28 Model C
48 Red Hunter
Michael.
28 Model A
28 Model C
48 Red Hunter
The B&B Carburettor I’m looking for.
- Attachments
- 093054CC-4CEA-459B-9A81-79955057AD0F.jpeg (24.33 KiB) Viewed 866 times
Michael.
28 Model A
28 Model C
48 Red Hunter
Michael.
28 Model A
28 Model C
48 Red Hunter
