Wanted 9/16w spanners
Has any one have 9/16 w thin spanners they don't need for rigid wheel taper bearing
adjustment.
adjustment.
Re: Wanted 9/16w spanners
hi you will find one on Ebay new or secondhand or boot sales or auto or bike jumbles there is lots of BSW spanners oo sockets around
hi Barrie ,if you need thin spanners you will find them , they are pressed out of flat steel the ones that was in the bikes tool kit , or what i do is grind the thickness of the spanner down to fit
I think the spanners you want are either 6606-27 which does the steering head adjuster nuts
too or 6606-30 the other use for which escapes me. 6606-30 seems to be available from
DraganFly.
The bearings in the back wheel can be fiddly to get right. There needs to be some small
movement at the wheel rim when all is tightened or the bearings will be swiftly crippled.
It was Paul Jameson I think who mentioned a figure of 1/32" on this forum earlier.
DraganFly.
Aren't the headstock spanners too big for the rigid frame wheel bearing nuts, at least at the front?
As you know, I'm a bit obsessive about original tool kits, and I have always wondered why the W/NG tool kit doesn't have a pair of spanners which I can use to adjust the front wheel bearings.
Thanks for the advice,drags have no stock at moment on the spanners I need 9/16 w, yes you are right may be tricky to ajust the bearings right.
Hi Barrie
have a look on Acme Stainless site, pretty sure Clay Jones does them.
KEEP LOOKING ON E BAY look at Ariel parts or classic motorcycle parts or second hand tools or spanners , they do come up often
I use a standard spanner, the jaws of which I cut in half with a hacksaw, lengthways.
Heres a link to Cornucopia spares in Germany who have a genuine Ariel cone spanner 6606-27/6606-30 for 15 Euros
https://www.cornucopia-enterprises.de/spares-ariel.html
