Something I am rubbish at
- adrian.hannam
Setting up a dial indicator on an Ariel frame to measures valve lift.
Editor "The Horse's Mouth" Australia
- Steven.Carter
Re: Something I am rubbish at
I can't change a tyre,
- Mark Nazer
Organising my life to give me time to play in the garage
Enjoy old age, you didn’t die young!
Steven.Carter wrote:I can't change a tyre,
I tried this the other day, with big clunky cable ties I could release with tiny screwdriver. (and reuse)
I couldn't get the tyre over the last bit without two "helps" from the levers, but there is no risk of catching the tube and it was much quicker
Administrator
webmaster@arielownersmcc.com
So I'm told, it's logical thinking that I'm rubbish at.
Bryan has a gnome on a sidecar by his front door which set me thinking.
I don't have a front door or a front garden so the choice was limited.
I didn't what a gnome nd being an Ariel man a pixie was the obvious choice.
They cost a fortune now when they do turn up. An Ariel 3 although it does
have three wheels is just plain silly.
So . . .
So . . .
HI the tyre fitting is a good idea but i would use tyre fitting soap or paste and not washing up liquid it has got to much salt in it but you have to get the old tyre off first you can use soap around the rim and old tyre to make it easier to get off
Finishing a job before I start on another one
- Bob.Murphy
PAINTWORK
- Steven.Carter
I forgot, wiring
Workshop organisation. I am lucky to have a very good shed but it gets rammed with stuff, half of which needs binnning!
Tom Walker
1955 4G.
1934 New Imperial 100
1934 Harley Davidson VL
1955 4G.
