For a 37project I'm looking for a complete brakeplate which fits to the girder fork. Including shoes, springs, adjuster etc. If n/a parts will help too.
Markus
And an upper chainguard for a rigid frame #5720-37
Thanks for looking 37 BrakePlate and Chainguard wanted
- markus.nikot
AOMCC German Branch Secretary
some Ariel - only Ariel
Re: 37 BrakePlate and Chainguard wanted
The main difference to later brakes is that later hubs from 1938 on are 1/8" wider. I have adapted later brake shoes without problems (and then got the linings bonded *and* riveted). The spindle for the brake cam has the separate bearing 4130-38 from 38, but to my knowledge that doesn't make any difference. So you can use all the later parts, as far as I know. Draganfly should have everything. I just would be cautious with brake shoes with linings that are only bonded.
The brakeplate on my 4G was damaged in the collision and will have to be replaced. It looks likely that a new one will have to be made. Would you like me to get another made for you?
