Does anyone know what type of chain adjusters a 1951/52 350 red hunter should have as they are missing from this bike?
Does anyone know or have a wiring diagram for a mag dynamo system? I will be making my own wiring loom so I need to know what amps the wires should be. The dynamo is Lucas E3LM-6V.
Ariel Plunger Frame
Re: Ariel Plunger Frame
The type is a threaded hexagon set screw, long. This one in fact https://draganfly.co.uk/shop/68967/whee ... /#4989-50Q
Wiring diagrams do not usually include specs for the wire. As your dynamo is rated at 60 Watts the max current any wire will take will be 10 Amps on 6 Volts or 5 if converting to 12 Volts. Diagrams are available in the Waller or Haycraft manuals
Dean
Adjuster is part 4989-50 (plus 1/4 CEI locknut) and screws into the top of the Ansty stirrup.
Wiring diagram: Pete
Thank you very much
I think that who ever had this bike before me , had started to turn it into a trail bike,all the tank brackets had been removed, along with the seat lugs , brake pedal lugs plus moor , iv made these parts and welded them back on ,it’s been like teeth, after your reply about the nasty link ,I’m now wondering if thay have been chopped down , can’t see any were that bolt could go , l will try and look at a complete one , this as answered a question thanks
Dean - there are 2 different types of plunger stirrup, the slightly earlier pattern used snail-cam adjusters not bolts.
See this thread, it has some pics of both types.
viewtopic.php?p=64665
That explains it all now . It’s should have the snail type ,but thay are missing, thanks for the picture s Pete ,very helpful
