Open valve rocker box 34-37 needed
Does anyone have a spare open valve rocker box? In particular the lower casting A5-405 as I appear to have an earlier incarnation of the casting that is machined to take un-flared pushrod tubes; i.e they would just go straight up into the casting, without the flare, rather than sleeving over the suitably cut bosses.
Re: Open valve rocker box 34-37 needed
You may well find it easier to obtain some pushrod tubes without the splayed ends instead, or to have some made. I used the early arrangement on my 350 engine for a while but changed to the later type to reduce grease leaks if I remember correctly.
I have a spare lower casting , however it does not have a casting number and the pushrod tube fittings have a flange to fit inside the pushrod tubes.
Let me know if it is any use, butthe casting is bare , no rocker shafts etc but it does have locating screws for the rocker covers.
Ian
Ian
Thank you Ian,
Presumably like this casting; actually a 350, but same joint to tubes?
Mark
Mark
Sorry here is missed image!download/file.php?id=30332&mode=view
Hi Markus
Yes, just like that,
Perfect!
I have sent a PM for further actions...
