WNG Rear Mudguard measures
- LuisPaz
Re: WNG Rear Mudguard measures
Thank You Johnny!
Today continue with the mobile stays
My read mudguard is Frankestain!
The angle is wrong... needs to be corrected
Luis, from Argentina
1944 Ariel WNG
1944 Ariel WNG
- alan.moore
Looking good Luis
- LuisPaz
Thank You Alan!
The screw to join stays to mudguard are 1/4 " diameter , and what thread?
https://www.draganfly.co.uk/index.php/c ... oduct/537-
Regards!
Regards!
1944 Ariel WNG
1944 Ariel WNG
HI Luis i think if they look like a fine thread it is 26 TPI CEI ( CYCLE THREAD ) or if it looks like a course thread it is BSW ( WHITWORTH ) that is the common threads that i use on most of my Ariel's some times i find someone has used different type of bolts and screws if they did not have the right ones like the ARIEL i am doing now it got lots of all different types of nuts and bolts with the wrong threads and nut sizes
- alan.moore
Luis
26 tpi cycle thread, same as the majority of the fastners.
alan
alan
HI most of the bolts and screws are 26 TPI but their is some BA as well on the bike but the engine and gearbox are mostly BSW
- LuisPaz
I need turning the mudguard stay nut..
Can tell me the hexagon size?
Thanks in advance!
Thanks in advance!
1944 Ariel WNG
1944 Ariel WNG
- LuisPaz
Today working with Lathe . Nut ready to cut and threading. I think this is NO correct nut to WNG because cannot put the pannier frame bracket....
1944 Ariel WNG
1944 Ariel WNG
- alan.moore
Adrie
Here are the two nuts from my WNG, as far as I know they are original. I had a problem in that with the pannier mounting brackets fitted I could not get a spanner on these nuts as they were too big. I then used two half width normal size 5/16 nuts with washers for the raised part to solve the problem. Cheers
Alan
Alan
- LuisPaz
Hi Alan!
Thank you very much for your help!
My head nut have 21/32.... they are a pair of bolts that I found in the waste can!
1944 Ariel WNG
1944 Ariel WNG
