Some works this week.
Many Thanks Simon for your information! http://ariel-square-four.blogspot.com/s ... l/pipe?m=0
Fuel Tap Filter and Pipe
- LuisPaz
Luis, from Argentina
1944 Ariel WNG
1944 Ariel WNG
Re: Fuel Tap Filter and Pipe
HI you have done a nice job of making a filter i like how you used the washer to make the shape at the top
- keith.mettam
How does the 'Reserve' work Luis ? With the just the filter as you appear to have it, won't the 'Main' fuel tap be supplying all the fuel from the tank ? When you run out with the 'Main' tap on the tank will be empty and there will be no fuel left for when you switch to the 'Reserve' tap.
Best wishes, Keith.
Best wishes, Keith.
- LuisPaz
Hi Johnny and Keith!
Thanks for yours reply!
Well the reserve i think has been short than normal.... my be a few miles plus then open tap...
I can enlarge the upper inside pipe.. I have not done tests yet...
I will have to carry and extra jerrycan!
1944 Ariel WNG
1944 Ariel WNG
