Hello to all hope you’ve had a good X-mas. I have tried to find in the forum my problem but could’nt find it
We talk about a magneto for a NG/NH. If i turn the magneto with my hand i have a spark over the breaker points. Sometimes over the igniter plug. If i connect the magneto to the engine and kick it there is no spark at all???? Now i believe that making an extra ground from the magneto to the engine eill help, but it is still a strange thing that it spsrks over the points. I have put new ground brush and igniter brush
Any one an idea?
Magneto sparks at points
Re: Magneto sparks at points
Hi Bram,
I think large sparks at points means the condenser is breaking down.
- Eero.Korhonen
Yes it is, unfortunately. You need to disassemble the magneto and change the condenser.
I usually put in modern ones and fill space with araldite or something similar.
Br, Eero
Br, Eero
Hi Eero
Can you give me some info about that condensor? Where to put it / connect it and which type?
Thanks Bram
Thanks Bram
Gentleman, i am talking about a magdyno. As far as i can see on pictures there is no condensator
- chris.shearwood
Hi Bram,
There is a condenser inside the magneto. Check out this web site for information with regards to your options:
http://www.brightsparkmagnetos.com/cond ... /index.htm
Regards, Chris
Regards, Chris
1946 4G and 1951 VH
I had one of these Brighspark condensors fitted some couple of years ago and the mag has performed faultlessly ever since.
Ian
Ian
Gentleman
Thanks for your redonses and the link. I will take it off and check keep you posted but be pationed. I have a lot of things going on
Wish you a happy new year
