Can tell me the correct torque and secuence to tighten the cylinder head?
Thanks in advance!
WNG Head torque secuence
- LuisPaz
Luis, from Argentina
1944 Ariel WNG
1944 Ariel WNG
Re: WNG Head torque secuence
There's no gasket so it's not particularly critical. Do opposites lightly at first and increase to full tension in about 3 sequences. There's no "give" so doesn't really need checking later. With a gasket on a twin for instance, I just get it hot and retighten it even before use on the road where it has a soft gasket with a lot of settling in. You might have to retighten a few times or you will get a leakage at the joint. Nev
- LuisPaz
Thank you for your reply Nev!
I had not noticed that between the head and cylinder there is no gasket ... and now that you say it, the parts manual is not listed.
Why is not Gasket?
ft/lb??
Why is not Gasket?
ft/lb??
1944 Ariel WNG
1944 Ariel WNG
Luis
It's a ground joint, the spigot on the barrel should seat on the recess in the head for the gas-seal with a very small clearance between the outer joint faces to make sure that it's the spigot that's doing the work.
The practice I follow for this is to finish lapping in the barrel and head with fine grinding paste on the spigot and coarse on the outer faces.
There is at least one fairly recent thread on the forum relating to this.
Ariel torque figures (for bolts and studs) were not commonly given, for the singles doing the head bolts 'tight' is usually adequate. I think the best figure anyone has arrived at is 300inch/lbs(25ft/lbs).
There has been some discussion on this as well - the level of official documentation can be seen in this thread!
http://forum.arielownersmcc.com/viewt ... 89&p=40462
(The doc referred to has all the figures for all the model range - don't expect too much!!)
Hope that helps
Hope that helps
- LuisPaz
Thank you very much Simon! Great info!
1944 Ariel WNG
1944 Ariel WNG
All pretty much covered. Don't overtighten any head that is threaded into to cylinder close to the bore as you may cause distortion in the top area near the bolts. With 3/8 x26 tpi ,25 ft Lbs is enough. Nev
