is there anyone that can sypply a correct handlebar to a 1934 Ariel 1"
Regards Lars
Handlebar Ariel 1934
- brenton.roy
Re: Handlebar Ariel 1934
Hi, Thanks, but i have the original, but its in bad condition, only good for pattern. Regards Lars
Drags have what you are after, part No 6400-34 for £34.50 which seems reasonable otherwise if you rent a pipe bender, buy the tube, have a couple of goes getting the bends right, then chrome, it will cost more than that.
I did see a nice set done in stainless, he had an exhaust shop bend the tube and he ran the cables in the bars tidying it up if not worried about being super original.
He drilled a hole for the cable then used a pointed rod to shape the hole so it did not chew into the cables.
I am going stainless myself, saves a bit of stress in wet climate/winter spraying the chrome all over the bike with Inox all the time.
Look forward to seeing your bike.
Brett
Brett
Hi, thanks. Have had this on backorder at Draganfly nearly 3 years.........
Have now made a handlebar in stainless, not 100% but good enought for me.
Will post pics when its ready.
Regards Lars
Regards Lars
