Ancient Ariel sign
wade.edwards
Ancient Ariel sign
I am tasked with creating a frame to hang this Ariel sign and would appreciate input. This is a double sided ceramic sign of unknown vintage but likely from the teens or earlier. If there is a way to positively identify a production date or where it might have been displayed, that would be helpful.
I don't want to make just any hanger as it should be age appropriate and suitably stressed to better match the wear displayed on the sign itself.
It will hang so that it is suspended through the two holes on the top edge.
All input appreciated,
Wade
Wade
Re: Ancient Ariel sign
Would a beaded edge tire (with rim?)be large enough to mount it in? , as a sort of resembling the early Serpent sign ?
wade.edwards
That sounds interesting, Vincent. The sign is 20 inches wide and 18 inches in height.
i would use some 25 x 6mm flat black iron and make a frame round it with a 8mm gap all round and fix it to the top with the two holes you can make it swing like wen they was outside a shop or workshop
wade.edwards
Thanks, Johnny. I have a good idea of how to structure it and of course I earn a living making things from metal, so this will be a fairly easy task. What I am hoping for is something archival,
like a picture of a comparable sign outside an Ariel shop from a hundred years ago. That would be over the top.
- jerry.mortimore
An early postcard. These signs are pre-1914. There are other signs, see http://www.arielcycles.me.uk/ephemera/signs.htm.
wade.edwards
Jerry, your submission is OVER THE TOP! That is exactly what we are looking for. Don't know how you found it but fortunately you did. Thank you very much.
Wade
Wade
Brian Petheram
They are available off the shelf for a tenner:
https://www.gardens4you.co.uk/aged-meta ... gb-en.html
there are many more on Google images
- Eero.Korhonen
Really nice picture!
Br, Eero
Br, Eero
- jerry.mortimore
Here is a large Ariel sign.....
