VG 32 Valve dimensions ?
johann.patek
Anybody out there who can supply dimensions of the valves for a 32 VG four valve head ? They appear different to the slopers though. Thanks in advance
Ariel 1930 model G special, Ariel SQ4 1957, Norton Commando 750, Norton Mercury, Norton 99, Norton N15CS, Velocette Venom, Velocette Thruxton, Velocette LE x2, Morgan F Super, Calthorpe Ivory 500, Yamaha sr500, Moto Guzzi Falcone
klaus gerhard
Re: VG 32 Valve dimensions ?
Hansi,
I think the VG and SG valves are identical. Which dimensions do you need?
Regards Klaus
Regards Klaus
stephen.fawcett
Hi,
Did you get the dimensions you need?
I have a couple of VH 32’s in bits these will be the same valves I’m sure.
Stephen
Stephen
hristo.kiskinov
For VH32, VG32 and SG32 (all 4-Valve) the part numbers are:
415-32 (A7/210a) inlet
445-32 (A7/173a) exhaust
and the measures for both types are:
- valve stem 9/32" = 7.14mm
- head 1 21/64" = 33.73mm
- length 3 13/64" = 81.36mm
- collet groove 1/4" diameter = 6.35mm
For SG31 (4-Valve) the part numbers are:
415-31 (A7/210) inlet
445-31 (A7/173) exhaust
and I do not know the difference.
regards
Christo
regards
Christo
