Front brake cable/rod assembly
Bought the parts I believed I was needing to complete the front brake cable/rod assembly on my W/NG from Draganfly, but clearly something is missing. Can someone give me a clue of what parts I need to complete this? The adjuster knob on the bottom end I know, that is on back order, so I'll make one myself (have got the special tap needed), and the spring is missing on top of the rod - but what else? There should be something to connect the cable to I believe, which is threaded on to the rod. Rod was sold as rod w/connector by Draganfly, fell off?
Ariel W/NG '40 "Bitzer", Triumph Thruxton '04, IZH-49 '56, Tempo Standard 150 '54.
Re: Front brake cable/rod assembly
Yes the bit missing is what I would have thought is very much a part of the assembly.. I can't post an image but someone will no doubt. It takes the cable end and has a small relief for the spring to seat on and it is threaded other end for the rod to screw into. I would Loctite that or solder it . to prevent it unscrewing. The coil spring pushes the brake rod so as to take the brake to off and is under the cover you already have. Nev
- LuisPaz
Luis, from Argentina
1944 Ariel WNG
1944 Ariel WNG
Ah, thank you. I will get in touch with Draganfly today and get one. I forgot a couple of other bits, so need to order more stuff anyway. Soldering seems to be a good idea, the threads on the rod is very short - easy to unthread or strip.
- alan.moore
I would also consider if that ball nipple on the cable is man enough for the job. There are other posts that deal with this which suggest making a barrel nipple out of a piece of brass bar with a hole through it, countersunk underneath so you can spread the cable strands out a bit when you solder it on. You have to solder it on after the cable has been threaded through the adjuster, sleeve/cover and the spring.T Barnes wrote:Ah, thank you. I will get in touch with Draganfly today and get one. I forgot a couple of other bits, so need to order more stuff anyway. Soldering seems to be a good idea, the threads on the rod is very short - easy to unthread or strip.
This is how I did mine:
Here is the complete assembly with the adjuster that screws into the boss on the forks
The thread on your rod looks a bit shorter than the one on mine (I got mine from Acme stainless) and when screwed on the end of the thread comes up to the base of the cable connector. If you have the die you could put a few more threads on the rod.
Acme Stainless also do the springs if you need one an sure he will be able o supply the adjuster nut if you need one.
Alan
This is gold! Thank you very much!
