NH/NG piston wanted
Posted: Thu Nov 08, 2018 8:10 pm
by T Batnes
Wish to get a .040 or .060 piston for an NH/NG 350, with either 7,5:1 or 8,0:1 CR. A used one is also of interest, as long as it's not damaged or totally worn out.
Re: NH/NG piston wanted
Posted: Fri Nov 09, 2018 7:46 pm
by Vincent.vanGinneke
Hello Tbarnes , one on Ebay from Egypt with contact address in Birmingham .
https://www.ebay.co.uk/itm/ARIEL-OHV-PI ... rk:11:pf:0
Posted: Mon Nov 12, 2018 2:32 pm
by T Batnes
Hi, thank you for the tip, but I'm afraid it's a standard piston with 6,2:1 CR, beeing a Hepolite 11210.
What I need is either a Hepolite 4469 (7,5:1 with three compression rings, no oil ring),
10431 (7,5:1 with two compression rings and one oil ring)
or 11548 (8:1 with two compression rings and one oil ring).
Posted: Mon Nov 12, 2018 3:47 pm
by paul.jameson
I had +0.020, +0.040 and +0.060 4469 pistons brand new in their boxes for many years. When I converted the Red Hunter back to 500cc about 5 years ago I sold off all my 350 bits. I found it extraordinarily difficult to sell the pistons which eventually went for little more than a pittance on Ebay.
Posted: Mon Nov 12, 2018 9:27 pm
by T Batnes
Wonder where they are now...
Posted: Tue Nov 13, 2018 1:48 am
by nevhunter
People "wanted " the more muscular") OHV's. As a callow (and poor ) youth I rode a 1936 Ariel RH 350 a 1947 ZA7 BSA 500 twin and then a 1948 Royal Enfield bullet with a swing arm frame. I only "pillioned" one bike, the Enfield and for a time it was my only transport to work, Uni at night ( the other side of Sydney and home (Newcastle) at the weekends.. The only mods to the Enfield was a roller big end conversion I fitted and some port reshaping.. I never felt the bike was inadequate with the power and the roller bearing lasted longer than the original floating whitemetal one fitted.. I did thrash it but liked it generally except the frame flexes and the gearbox was an Albion that stuck in two gears at once, once. Nev
Posted: Fri Nov 16, 2018 7:03 am
by tony.barnett
Have you tried Single Spares?
Posted: Sat Nov 17, 2018 3:56 pm
by Brian Andrews 2180
Hi Tony hope all is well in Swindonia can you give us a call re piston 01843 293370 regards Badger.
Posted: Wed Nov 21, 2018 8:14 pm
by T Batnes
Found it, Draganfly had a kit with a std 8,5:1 piston and a cylinder liner. So got another cylinder today, and will get it lined and fitted with the 8,5:1 piston. Maybe a tad high CR, so I should fit a shim under the cylinder, or mill the crown little bit...?
