Wanted: Lucas DU 142 8 inch headlamp
ianstephens
Post by ianstephens »
Hello
I’m looking for an original Lucas 8 inch DU 142 headlamp (flat, fluted glass with an instrument panel) for my 1934 Ariel LH Red hunter.
As my bike is 1934 ideally the shell should be in brass but I would be happy to accept a later model (as long as it is not a modern copy).
Any help or suggestions would be greatly appreciated.
Many thanks
Ian
ray.tolman
Re: Wanted: Lucas DU 142 8 inch headlamp
Post by ray.tolman »
Hi Ian,
I have as surplus this early Lucas, 8" brass shelled headlamp painted and ready to use. I think it is a DU142 but stand to be corrected.
I live in BC, Canada
Ray
fpassmore
Post by fpassmore »
Hello Ray,
If Ian is not interested that would go very nicely on my '36 RH Twin Port or the SB31 Sloper, I believe. I have one but a later repro pressed steel one.
Frank
ray.tolman
Hi Frank,
Thanks for the interest. If Ian is not interested you are next in line.
What project are you working on now?
Cheers.
Ray
ianstephens
Many thanks Ray, I’ve sent you a PM.
Does anyone know where I might find the glass, reflector and rim. I already have a suitable panel.
Best wishes
Ian
alan.moore
Post by alan.moore »
Ian, I got my rim from single spares and 'replica' fluted glass on Ebay. However, it looks as though you are after original parts so cannot help if that is the case.
Alan
klaus gerhard
Post by klaus gerhard »
Hello Frank,
I think a SB31 would use a Lucas H52 headlamp!
Regards Klaus
chris.vredenbregt
Post by chris.vredenbregt »
You know the price of a h 52 Klaus?
paul.jameson
Post by paul.jameson »
You will find that the replicas made by the Czech boys are extremely good if you can't find an original (as I couldn't for the 1936 Square).
paul.jameson
As an afterthought, if you need the correct original glass, go to a car autojumble where they are (or used to be) common enough. They are like hens teeth at bike autojumbles.
