FRONT BRAKE CABLE TO ROD DETAILS ---1938 ariel square four
Posted: Wed Jan 10, 2018 10:03 pm
by ralph thetford
Can any one help--1938 Ariel square four----Where the front brake cable goes from a cable to a rod is a short tube with a spring inside followed by a cable to rod connecter ---Can someone help me with the dimension of the spring--length, outside diameter and wire thickness and confirm how it all goes together-----Regards Ralph
Re: FRONT BRAKE CABLE TO ROD DETAILS ---1938 ariel square four
Posted: Thu Jan 11, 2018 4:06 am
by nevhunter
How much of the assembly do you have? Nev
Posted: Thu Jan 11, 2018 12:33 pm
by ralph thetford
Hi Nev,
I have the rod, cable connecter, and tube, but have not got the spring --I would like the dimensions of the spring so I could try and get hold of one and details of how it all fits together.
Cheers Ralph
Posted: Thu Jan 11, 2018 12:49 pm
by ian.scott
Why not just buy one from Draganfly ?
Spring, front brake rod 4752-27 £ 5.94 (£ 4.95 excl VAT) each
Ian
Posted: Thu Jan 11, 2018 11:02 pm
by ralph thetford
Hi Ian, thank you for your time to answer but I have tried Draganfly but they are out of stock
Cheers Ralph
Posted: Fri Jan 12, 2018 1:28 am
by Richard Kal
Acme Stainless should be able to help.
Excellent quality.
http://www.acmestainless.co.uk/results_ ... ategory=81
Richard
Posted: Fri Jan 12, 2018 10:48 am
by ralph thetford
Problem is Richard I don't know the size---length, diameter and wire thickness
Cheers Ralph
Posted: Fri Jan 12, 2018 11:35 am
by simon.holyfield
Acme would provide the whole assembly Ralph, but if you don't want to go that way I can measure the spring from my W/NG. I note that this has a -27 part number and is the same for all models, if that is any good to you. It is a Draganfly part.
Posted: Fri Jan 12, 2018 12:18 pm
by Richard Kal
Hi Ralph,
These measurements from a new spring supplied by Draganfly:
Free length: 1.530"
Wire diam: 0.038"
O.D: 0.353"
I.D.: 0.270"
No of turns: 11
closed (coil bound) height: 0.436"
Force at fully collapsed height: 15 lbs
Richard
Posted: Fri Jan 12, 2018 11:03 pm
by ralph thetford
Thank you Richard that is a big help
Cheers Ralph
