Aerial model G -?
markthatcher
Aerial model G -?
Hi every one just brought a Ariel 1930 500 ohv you can google on you tube I was looking for your comments neg or poss thanks mark
- chris.vredenbregt
Re: Aerial model G -?
Do not understand what do you want to know ik have one g_special...Chris
Last edited by chris.vredenbregt on Sun May 21, 2017 6:36 pm, edited 1 time in total.
- dave.owen
Have you got any pictures, engine and frame box would help the experts
Dave
Dave
markthatcher
Hi the bike came from the neatherlands I have had bikes when I was younger but am not an expert but just could not resist this great Ariel I know it is not compleaty original as items got changed as life go's on it is on you tube Ariel model G 1930 500 ohv I am hopeing that the more knowledgeable would pass a comment the frame no/k3298/engine/k6705/gearbox/QD39820 thanks to all for your comments
- chris.vredenbregt
Gearbox should be QDH magneto kr-1 both very expensive items not sure about the numbers will check when I am home again ...Chris
- dave.owen
Even if it's not a model G, a 500 black Ariel is a fine machine
Dave
Dave
- chris.vredenbregt
I am thinking it might be a model F but you are right Dave
markthatcher
Thanks for the comments my thinking is that it is not a G when I brought it looked at a lot of pics to make comparisons the frame and engine numbers seem to make sense not easy to come to a positive conclusion thanks for your time
markthatcher
Confirmed by the factory yes model f with special order 21 tooth engine sprocket /tank fittings nickel/twist grip throttle/ so all looks good
- PeterW
This one?
