Hi all,
I need help with restoration my squareariel. I can not find distributor cap. I know it is no possible found original. But I don´t know which distributor cap is possible fit on this bike.
My second problem is Doherty handlebars 1932. I am found handlebars, twist grips and levers. But I can not found dimmer switch, horn push and kill switch.
I know it is almost impossible found this item. Please send me at least photo or drawing this item.
Or if you have any photos and information about this bike
Thanks for your help
Milan
square four 4F6 1932
- markus.nikot
Hi Milan,
You could use distributorcaps for Triumph TR 4 cyl cars. You only have to shorten the cap around 5mm. Beware that the cableterminals are inline with the clipholders - so the cables facing to the rear of the bike. Other caps with 45degree offset terminals availiabel and the HT cables then facing upwards, if you ride in rain you'll have a lot of fun with sparks at wrong places.
Markus
Markus
AOMCC German Branch Secretary
some Ariel - only Ariel
