Lube oil for topping up Burman GB
Mark.Ogden
Post by Mark.Ogden »
Chaps
I have used EP90 - about 250cc - to top up the 52 GB Burman box. Am I in deep do doo? Cannot seem to find a definitive repsonse as to what is acceptable/unacceptable.
Obrigado
Mark
Andyozz
Re: Lube oil for topping up Burman GB
Post by Andyozz »
Hi Mark
I personally would not use any extreme Pressure (EP) lubricants in Burman or any old gearbox with internal bronze bearings in as the EP additive will actually attack the bronze bushings over time.
EP lubricants are really designed for gearboxes with roller or needle bearings in.
Morris Lubricants do a straight 90 which I use in all my gearboxes and have covered several thousands of miles with no problems.
Hear is a link to the data sheet
http://www.morrislubricants.co.uk/Downl ... 20Oils.pdf
Additionally, some early Burman gearboxes use a grease and oil mix (50/50 if i remember rightly with a LOW melting point grease). The grease was primarily to keep the lubricant in the box as the seals were either non existent or very poor.
Andy
