Wanted Gearbox parts
Lars.Lindboe
Post by Lars.Lindboe »
Need parts for a 3-speed burman gearbox ca 1930. Bike is 500ccm OHV.
Need the two gears for high speed, Big gear has 29 teeth, small one has 21 teeth.
will try to post pictures, Thanks, Regards Lars, Norway.
Those are the first ones to wear, as they are constant mesh and used in every gear but top.I think they may be hard to find, but could be remanufactured, though not the simplest. Nev
Lars.Lindboe
Re: Wanted Gearbox parts
Hi Nev,
This gearbox have had a hard life, and with a worn out bronze bushing and a to tight chain things go bad fast....
Hope someone can find me a set, not easy to get someone make these anymore. Thanks.
Regards Lars
adrie.degraaff
Post by adrie.degraaff »
I have welded soft new tooth on a Vincent Rapide gear, giving no problems after, your not going round the world on it.
Lars.Lindboe
Hi, Think maybe possible to weld the small gear, but the big one is pretty worn all over. Regards Lars
MartinMastad
Post by MartinMastad »
ring 90766071
Martin :)
Ariel 1930 Model G Special, DKW RT100 1934, Tempo moped 50cc 1958, Honda CB350F 1975, Honda CB500F 1975, Honda CB125TA 1980, Honda CB1100F Super BOL D'OR 1985
