Help - my SS49 headlamp reflector is stuck
Posted: Tue Nov 24, 2026 12:38 pm
by andrewhawkswell
Hello all - looking for any tips that anyone may have had who has met this issue before.
I have a Lucas SS49 headlamp that I want to fit to my Ariel Model E 1928. I received the headlamp with the cover locking ring and the reflector loosely assembled and no glass or sealing rubber. I put the parts I have together to check the fit and during this the reflector was pushed home into the body shell to allow the bayonets to enter.
I now find that try as I might the reflector is well clamped into the body and I can't get it free with normal hand pressure, or gentle leverage with a thin tool through any of the three bayonet slots against the back of the reflector rim. Inside the shell there are 3 spring loaded clips which are gripping the reflector rim edge, but I can't see how they work - I feel bit foolish as I would have worked this out but the reflector is now in the way- I don't know if there's a trick to release them; they are holding on for dear life and I don't want to crush the shell or refletor. I could drill out the brass rivets that are holding these clips to the shell but that seems a bit extreme.
Re: Help - my SS49 headlamp reflector is stuck
Posted: Tue Nov 24, 2026 1:16 pm
by simon.holyfield
I imagine you've seen this?
I have an H52 in bits and can go and have a look at it, but I don't have any first-hand experience of the SS49 and it might not help...
