Headlamp dashboard seal
Posted: Sat Nov 14, 2026 7:39 am
by klaus gerhard
I wonder how to fit the sealing rubber to my headlamp shell. Is there a proven pattern and whats the appropriate diameter of the rubber cord?
Klaus
Re: Headlamp dashboard seal
Posted: Sat Nov 14, 2026 8:03 am
by Paul Gasson
Hello Klaus,
This is my 1950 light shell before renovation. The rubber was cut into three pieces and two followed the long black lines front to back on the shell with a short piece in the outer set of holes across joining the long strips. I hope this helps you?
Posted: Sat Nov 14, 2026 8:45 am
by simon.holyfield
Posted: Sat Nov 14, 2026 1:27 pm
by Chris Sealy
Who knew that. When I renovated my headlamp, it had no seal; therefore I used edging strip.
This is the, new thing, that I have learned today.
Posted: Sat Nov 14, 2026 3:51 pm
by simon.holyfield
Chris Sealy wrote: Sat Nov 14, 2026 1:27 pm
I think they vary a bit. The one in my picture is marked as a DU42 - the SSU700 I have fitted to the Mk1 doesn't have those seal holes...
Posted: Sat Nov 14, 2026 10:33 pm
by klaus gerhard
Great. That helps a lot. Did you use a 2mm rubber string?
Thanks very much
Klaus
Posted: Sun Nov 15, 2026 8:32 am
by simon.holyfield
klaus gerhard wrote: Sat Nov 14, 2026 10:33 pm
Thanks very much
Klaus
I think so. I'll measure it later.
Posted: Sun Nov 15, 2026 9:35 am
by Paul Gasson
I bought mine from Drags, not sure what thickness was but reference 516524A and only £0.98 for a long enough piece. Looks like they reference it for all similar headlamp assemblies.
Posted: Sun Nov 15, 2026 3:47 pm
by simon.holyfield
Apparently I bought 2 mm sponge EPDM round section, according to my historical eBay purchases!
