Re: CP gearbox
david.anderson
Re: CP gearbox
Post by david.anderson »
Can anyone provide dimensions for the gearbox sprocket spacer 3112-33 for a CP gearbox, in particular the length, thankyou
david.anderson
Re: CP gearbox
I found an older post by Alan Moore which gives the width as .762" whereas the BA spacer is .435"
viewtopic.php?t=9604
Re: Re: CP gearbox
It makes sense that it would be longer. It's usually worn where the seal runs on it as it's not hardened, so I usually make a new one as a new old stock one would be soft also. The sprocket retaining nut when tight with tab washer ends up with the sleeve gear threaded end about '020" Proud. Nev
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 10 guests
