Pushrod tube rubbers
charles.bulloch
Post by charles.bulloch »
Hi, all
I have new pushrod tube rubbers and also an old Britax gasket set from ebay. The Britax set has one pair of rubbers slightly shorter than the new set. Hopefully I can now mount the head without trimming the rubber.
Is there a decent way to shorten these rubbers smoothly so they don't leak oil?
Charlie
Re: Pushrod tube rubbers
Not to My knowledge. See if they compress enough without undue Pressure. Nev
charles.bulloch wrote: Fri May 08, 2026 4:32 pm Hi, all
Charlie
Isn't one end supposed to be shorter than the other? I can't remember which way around they are.
charles.bulloch
Hi, Simon,
the modern ones are all the same length, mostly.
Users browsing this forum: Bing [Bot] and 6 guests
