Rear break plate spring to cam lever
wade.edwards
Spent a lot of time searching the Ariel universe for advice on this application: Back to Basics, the Club library and You Tube.
Fresh powder coat on the rear 1946 NH, brake plate and do not want to scar it using screwdrivers or any other instruments of torture. Took it apart five years ago.
Got to get that return spring around the cam lever (done) but now to stretch it over the fulcrum without chewing the paint.
Is there a quick success video on any platform?
Thanks
Thanks
Re: Rear break plate spring to cam lever
In the past I've been known to use strong tie wraps looped around the spring and now I have one of these hooks:
https://www.venhill.co.uk/long-shank-sp ... -vt11.html
Both will preserve your powder coat.
I've also made this to expand the shoes for fitting, it will allow the cam to be rotated when not under spring pressure and make fitting the return spring easy - another option;
Remove shoes, fit spring, re-fit shoes.
wade.edwards
Appreciate the advice. Somehow I wasn’t clear.
Got the shoes on by placing one side and hinging, pulling and dropping the other set into place.
I was talking about the OUTSIDE, FRONT, coiiled return spring for the brake arm.
It’s a bugger to pry into place.
The plate is on the bench and tricky to hold down. Perhaps the best option is to install the wheel into the frame, then install the brake plate anchor stay to the frame. At least it won’t be sliding around.
- Keith.owen
Or, do as I do.
Fit shoes, springs, cam etc.
Put lever on cam and carefully rotate until the cam is at 90 degrees to the brake shoes ( if in the right position the pressure will hold it in this position). Now, fit the brake lever and fit washer and retaining nut; tighten enough to ensure lever is firmly in place (holding the lever with one hand so that the cam doesn't move).
Now, carefully move the lever so that the cam returns to rest position, and in getting there, engages with the spring.
Simples (but it took me a while to figure this one out).
Keith Owen
Past Editor - Cheval de Fer
1950 Rigid Ariel VH
1951 Rigid Ariel NH
1952 Plunger KH
1950 Rigid Ariel VH
1951 Rigid Ariel NH
1952 Plunger KH
- Keith.owen
Forgot to say, with cam at 90 degrees, remove lever and drop spring into position, tail in the hole, then fit brake lever again, before carefully moving it clockwise so that the lever engages with the spring.
Sorry!
Sorry!
Keith Owen
1950 Rigid Ariel VH
1951 Rigid Ariel NH
1952 Plunger KH
1950 Rigid Ariel VH
1951 Rigid Ariel NH
1952 Plunger KH
wade.edwards
Thanks for the advice.
I was not confused about which spring you meant and it is still easier to fit the cam with spring before the shoes
wade.edwards
Okay, I see what you are saying, Roger.
The explanation seemed to refer to the fitting of shoes, without referencing the brake arm return spring.
Got it now. Thanks
Got it now. Thanks
