Page 1 of 2
Semi Fluid Grease for Gearboxes
Posted: Wed Mar 18, 2026 1:39 pm
by Keith.owen
Hi,
I have always used Penrite semi fluid grease but it is now becoming hard to come by.
Can anyone suggest a good alternative? Also do people mix their own and if so, what is the recipe?
BR,
Keith
Re: Semi Fluid Grease for Gearboxes
Posted: Wed Mar 18, 2026 2:33 pm
by Roger Gwynn
I use
https://draganfly.co.uk/shop/83795/gear ... 11/#OI-GRB well I would, wouldn't I. 750ml rather than 500ml of the Penrite
Posted: Wed Mar 18, 2026 8:15 pm
by simon.holyfield
I use the Morris one - K400EP?
Posted: Wed Mar 18, 2026 9:11 pm
by Alan G
https://www.ebay.co.uk/itm/391925159143 ... R_q7waygZw
I have a tub of this, not used it yet - but expect it will be fine, blurb says it is for vintage car and bike gearboxes, and is under a tenner....
Posted: Wed Mar 18, 2026 9:14 pm
by dave.owen
Keith, you could pick some up at kempton park auto jumble
Dave
Posted: Thu Mar 19, 2026 2:22 am
by nevhunter
I usually mix my own with Tacky Mill grease and a thick gear OIL. The Penrite Product is easily available HERE in Au and the exchange rate is very much in the UK's favour,. As long as it POURS it will not channel. Nev
Posted: Thu Mar 19, 2026 7:35 am
by klaus gerhard
I get mine from a local tractor repair shop. They charged about 11 Euro for 1 Kg.
Posted: Thu Mar 19, 2026 11:17 am
by Keith.owen
Hi there!
Thanks for the suggestions; I don't want to do something that i will later regret!
Much appreciated.
keith
Posted: Thu Mar 19, 2026 11:23 am
by volker.halbach
I am using grease with viscosity NLGI 0 (there are also the more liquid grades 00 and 000); others use NLGI 00. I top up the gearbox with a syringe.
Posted: Thu Mar 19, 2026 4:21 pm
by fpassmore
Here in North America I have started using the John Deere “ Corn Head Grease “. It is available quite readily and a 01 grease so quite fluid. Pricey but the best availability here although I have an acquaintance who is a vintage MG owner and I have used his contacts a few times.
