1929 crankcases
1929 crankcases
Has anybody got a pair of 29 crankcase I need some to get my frame sorted out I don't mind how rough as long as the mounting castings are there for the bolts to go through, damaged faces, barrel fixing damaged don't worry or hole in the sides as long as I can line up the bolt for the frame and mounting plates to straighten the frame to the correct position instead of some 1/2" plates to take up the correct position at the moment, thanks clive. I should be at the Ariel do at Burton in A few weeks.
Re: 1929 crankcases
Due to the wonderfulness of Ariels any crankcases from 1929 to 1958 will do.
Re: 1929 crankcases
Thanks very very much Roger that makes it a lot more simple good old Ariels Regards Clive.
