Vh500 Gaskets
Posted: Thu Jul 24, 2025 7:17 pm
I have a significant amount of oil coming from somewhere around the head.... Iron twinport head.
The rocker cover gaskets look intact, but old. I removed, cleaned and smeared with grease before putting the covers back on - gut there is still a lot of oil getting everything nicely rust proofed.
There is a fair degree of wiggle on the decompressor. But I have not yet done a talcum powder check to see if I can find where the oil is coming from.
So... planning on replacing the gaskets - are the 1.2mm flexioil ones on ebay any good ? - about £5 a pair delivered.
Is there a serviceable seal on the decompressor? Is "wiggle" normal or should it be tight and rotational only?
Any other "must look at"s?
