Leader Wing mirror kits now for sale
Trev Sellars
Post by Trev Sellars »
At last these kits are now available to club members only.
You can order them as a kit and
MAGAZINE ADVERT FOR MIRRORS.pdf
(537.96 KiB) Downloaded 239 times
build it yourself, just immerse the housing in boiling water for 10 mins and then stretch the housing over the glass, as in the original design. Put the coach bolt and smaller domed washer in first! The coach bolt, washers and nuts are as in the original design except they are metric not imperial and the glass is mirrored convex, again,same as the original.
These as you may know from previous posts are 3D printed, having been reversed engineered and reproduced. They are exact copies made from flexible material but the finish coat of paint can be applied to match your colour design if required.
The price is as low as we can go and the club are making only minimal profit on each mirror, this way, if we sell 100 mirrors, then the set up costs and reverse engineering costs will just about be covered. You cannot buy these anywhere else.
Last bumped by Trev Sellars on Fri Jul 11, 2025 2:25 pm.
