Occasional primary side noise -Mk1
camstevens
Post by camstevens »
Hi. Does anyone know what noise(es) a loose crankshaft spherical roller outer would make? Occasionally I get a clack-clack from what I think is the primary side of the engine. A bit like a harsh tappet....but sometimes not completely synchronous. Only happens if the engine is quite hot, but doesnt alway happen. I don't think it is the primary chain, which currently has about 20mm up/down play. My head keeps going to a bearing issue....probably the outer when hot. I imagine an issue with the rolling element would be a constant noise.
Cam
camstevens
Re: Occasional primary side noise -Mk1
Oh, and I meant to add that noise only occurs at slow idle....slight raise in revs and noise disappears
Cam
That sounds just like the coupling gears to me...
camstevens
I hope so...if so I'll pretend I can't hear it :)
camstevens wrote: Sat May 17, 2025 2:46 pm I hope so...if so I'll pretend I can't hear it :)
That noise is one of the motivations behind fitting electronic ignition - I've not tested it yet, but I'm hoping that if it evens out the ignition of each cylinder, the coupling gear noise might reduce.
I can't help feeling there's a bubble waiting to burst...
Post by will_curry »
"They all do that Sir . . ."
Owner's Guides all contain the following couple of paragraphs in the "Driving Tips" section:
which suggests that knocking from the coupling gears was common enough for
Ariel to have to formally acknowledge it.
camstevens
simon.holyfield wrote: Sat May 17, 2025 3:04 pm
Bubble waiting to burst? I hope that doesn't meant a blown engine 😳
camstevens
I think there's a lot of merit in using electronic points .....my distributor points have worn unevenly to the point where there is around 0.005" variation from smallest to largest gap. I'm sure the CDI unit would even this out resulting in a smoother idle. Cam
camstevens wrote: Sat May 17, 2025 5:43 pm I think there's a lot of merit in using electronic points .....my distributor points have worn unevenly to the point where there is around 0.005" variation from smallest to largest gap. I'm sure the CDI unit would even this out resulting in a smoother idle. Cam
I'm sure it would. I've got a positive earth Accuspark sitting here doing nothing...
camstevens wrote: Sat May 17, 2025 5:39 pm Bubble waiting to burst? I hope that doesn't meant a blown engine 😳
No nothing like that! I'm just thinking that maybe I'm being naïve in hoping the coupling gear rattle will improve.
Users browsing this forum: Mark.S and 0 guests
