Page 1 of 2
Correct name for bulb fitting
Posted: Sun Jan 26, 2025 3:58 am
by bevanclark
Hi folks,
Could someone please tell me the correct name/description of this type of bulb fitting ? It is a 6V 45W Marchal lamp with 3 locating pins spaced at 120 degrees and a single filament connection at the bottom - see image.
Also: is there an LED replacement ?
Thanks,
Bevan
Re: Correct name for bulb fitting
Posted: Sun Jan 26, 2025 8:19 am
by simon.holyfield
What's the diameter of the cap?
Posted: Sun Jan 26, 2025 6:34 pm
by JohnnyBeckett
i think it maybe a old bus or coach interior lighting bulb
Posted: Sun Jan 26, 2025 10:55 pm
by Pete.Silson
Is this what you are looking for?
Posted: Tue Jan 28, 2025 6:20 am
by bevanclark
The bulb has a 2 cm diameter base. It is fitted to a 1929 Duciellier headlamp which a previous owner fitted to my BSA Sloper (it left the factory in 1929 without a lighting set.
I'd like to replace it with an LED bulb if possible.
Posted: Tue Jan 28, 2025 8:48 am
by simon.holyfield
bevanclark wrote: Tue Jan 28, 2025 6:20 am The bulb has a 2 cm diameter base. It is fitted to a 1929 Duciellier headlamp which a previous owner fitted to my BSA Sloper (it left the factory in 1929 without a lighting set.
If you Google BA21S, you'll find folk selling LEDs to suit!
Posted: Tue Jan 28, 2025 7:30 pm
by bevanclark
Thanks Simon :).
That BA21S code is exactly what i was trying to find out. Google brings up images just like my bulb, although most are 12V. I have been musing on whether to return the lighting to dyno operation - my MDB1 dyno is not connected at present; it is running lights off a battery, so i could actually go to 12V if needs be. I'm not worried about authenticity since it isn't the correct headlight and the bike had no lights at all in 1929 anyway.
Cheers,
Bevan
Posted: Tue Jan 28, 2025 11:12 pm
by simon.holyfield
It's all thanks to Pete Silson really.
Curious as to what headlamp you have, to use a bulb like that?
Posted: Wed Jan 29, 2025 7:27 am
by bevanclark
Hi Simon, maybe from a French vintage car ? Apparently period correct but obviously not BSA. The bike was exported directly from the factory to Hungary where it spent almost 90 years of its life.
Cheers,
Bevan,
Ps.
sorry everyone for the non-Ariel questions - this forum is a lot more active that the BSAOC one !
Posted: Thu Jan 30, 2025 7:37 am
by ian williams
MARCHAL ba21d double filament led
https://www.classiccarleds.co.uk/produc ... Q0tdvepIkr
looks like they come in either BA21S SINGLE or BA21D DOUBLE filament depending on what you want or want to setup in your headlight .
link for single
https://www.ebay.co.uk/itm/174779761634 ... gLWJfD_BwE
