Anchor plate/damper rod
wade.edwards
Post by wade.edwards »
Don’t have an Ariel with tellies but nevertheless have a few bits around.
The anchor plate doesn’t look like the catalog pic, so what is it?
Also would like to know if the steering damper rod is correct for 46-58?
Re: Anchor plate/damper rod
Hi Wade, this is how it looks from my bin. :D
and will end up on the VB.....one day
wade.edwards
Thank you for answering, Vincent :D
Looks like I have some other than Ariel bits :shock:
The last of the W/NG didn't have one. nor was the frame drilled out for it.. Nev
Neither did the 1956-58 NH.
John.Cheetham
Post by John.Cheetham »
1955 NH also.
Still learning, I never knew that.
Correction, I did know it but had forgotten that I knew it! I have proof 'cos I wrote it down.
John.Cheetham
Draganfly website description for 4834-55 is "Steering Stem Nut" 1956 to 1958
Should be "Steering column plug" 1955 to 1958
Thank you for the correction, I shall pass it on.
