Good afternoon
I am looking for an Amal float bowl for my WNG please. I believe it should be 15 degree angle. Its for a non standard 276 carb.
Many thanks
Adam
Wanted Amal 15 degree float bowl for a 276
Re: Wanted Amal 11 degree float bowl for a 276
W/NGs normally use a 15 degree float chamber, which are available from Amal.
Ah perhaps thats where I am going wrong! I thought I measured 11 degrees and must of read somewhere that it was correct! There are a few 15 degree ones on the bay so will perhaps make sure its correct then purchase
Thank you Simon!
Thank you Simon!
Re: Wanted Amal 15 degree float bowl for a 276
Have changed the title in the mean time, thank you
