Greas gun for small grease nipples
MikeCrook
Post by MikeCrook »
Hi, I've not been able to find a suitable grease gun or adapter to lubricate the small nipples ,
Any suggestions i have contemplated removing the nipples and using a syringe to grease.
Thanks
Re: Greas gun for small grease nipples
I use a modern grease nipple and laboriously (its not that bad) swap them, grease them and swap them back again.
Jim Fitzgerald
Post by Jim Fitzgerald »
The old school way is to place a layer or two of woven cotton material (bedsheet) over the nipple. A modern gun fits ok then. The grease finds its way through the weave of the material when you pump the gun.
Jim
Post by Simon.Gardiner »
Put a small piece of cloth (or maybe a couple of pieces) over the nipple. You'll find the grease will push through the cloth and not come out the sides. (Does need a push-type gun and you need to be square on the nipple.)
Post by JohnnyBeckett »
hi i use a grease gun that comes with a old myford lathe for small grease nipples
SimonFletcher
Post by SimonFletcher »
A quick search on eBay will turn up quite a few of these under different brand names but all essentially the same. If you can find one with the longer nozzle, it’s useful to get into those hard to reach spots. I intitially bought mine to reach in through the spokes and grease bicycle hubs, but the nozzle at 0.6mm ID is small enough even to depress the centre spring loaded ball inside a standard nipple and apply grease through that too…
Look for ‘mini grease gun’ or bike/bicycle grease gun.
Here is an example: https://www.ebay.co.uk/itm/154715741328 ... media=COPY
’54 VH,
‘72 BMW R60/5, ‘83 BMW R80RT
MikeCrook
Post by MikeCrook »
Thanks all,
I have now ordered the suggested parts and be out on the road confident that all is lubricated.
