W/NG Timing Case Wanted 1943
Parts needed or for sale, which are unique to the W/NG.
Suppliers of unique Ariel parts.
tcolbourne
Post by tcolbourne »
Looking for a timing gear case for 1943 W/NG. The one fitted now appears to be from a mid 1950's bike as it has no rocker feed fitting.
Re: W/NG Timing Case Wanted 1943
Someone may be able to swap your s for the correct one. The outer cover has nothing written on it and no webs on the inside.Nev
tcolbourne
thanks for the info---i have the correct steel chain cover. I"m also looking for a correct W/NG clutch dome--i think drags has them maybe but very costly. i'm willing to swap the gear case -- i'll be dismantling the engine so will be able to get a good picture of it. Also looking for primary cases (good luck finding those--i have some beat-up ones that i may be able to get to work)
