what model is my 1947 ariel?
I have just bought my first motorcycle which is a lovely ariel, but i am unsure to what model it is. It looks like a hunter to me but is there a code on the bike i can check?
Wayne Martin 1934 twin port VH, 1927 Model E Supersport,1959 Triumph 5TA Bobber,
Hi Wayne. The timing cover might have letters, VH, NH. These are the hunters, 350 and 500.
Otherwise, there are a number of differences, which might require removing the sump cover or carby to confirm.
The engine number will give a clue and a photo would also help.
Both Hunters had 20" front wheels.
regards, Brenton
regards, Brenton
The Hunter's are the top road models and have some "extra" features The main difference in the singles is the steel flywheels ( Up to about 1953?) polished ports, 20" front wheel. tank colour?
post war engines have NH, VH on the magneto chain drive case. The prewar ones have RH 350 and RH 500 . These can easily be changed though.
The main thing is the steel flywheels. You can check these by removing the rectangular cover on the bottom of the engine and having a look at the flywheels the steel ones are polished with rounded edges. While you are there remove the sludge trap bolt carefully with a 7/16 Bs or !! mm spanner may fit tighter. and clean it out. Remove the sludge . It is a hollow bolt, and the sludge can be quite hard. If you have just bought the bike and you are not entirely sure of it's service history, remove the oil tank and clean it thoroughly. Often there is a lot of settled sludge on the bottom of the tank, that is not obvious till you have a bit odf a dig at it.
Ensure the grease in the gearbox hasn't gone hard. It needs to flow to get around the gears. ADD thick oil if you are in doubt. This is all worth doing but don't let me scare you off. Happy riding. Nev
Re:
Hi Dave,dave.owen wrote:What year is it, if its an Iron engine ,the 500 has a 1" flange on the bottom of the barrel, the 350 less tha 1/2"
Dave
That's an interesting one. I have a couple of thin flange 500 barrels - like the 350. I don't think they're either common or desirable!
regards, Brenton
- john.nash
BK prefix were originally 500/600 crankcases. 1947.
I believe singles crankcases are interchangeable, although the sidevalve has a "drainhole" above the camgear and the later ones turn that into a threaded hole for the fifth barrel stud. Someone correct me if I am wrong here ...
After a certain date in the 30's.( To do with the primary chaincase) I think they will interchange right through till the last. The 1951's have a different "Look" under the platform that the cylinder sits on. I'm not sure if the sidevalve tappet chest drain hole lines up exactly with the VHA and later stud. The VCH has 6 (six) studs holding the barrell on, so it's noticeably different. Nev
