Posted: Sun Feb 21, 2021 9:08 pm
by Steven.Carter
Swinging both ways
Definitely needs fixing
Posted: Mon Feb 22, 2021 12:59 pm
by JohnnyBeckett
hi Steven that is a nice rear wheel steering on a Ariel
Posted: Tue Feb 23, 2021 12:51 pm
by Steven.Carter
It was getting a bit frightening Johnny .
Bit of wood rammed in just allows it enough space to get it out
Posted: Tue Feb 23, 2021 1:02 pm
by Vincent.vanGinneke
Steve, where those bushes 'new' vulcanised rubber ones or the bronze ones you made a while ago?
Posted: Tue Feb 23, 2021 1:19 pm
by Steven.Carter
Those bushes above are new rubber ones that I bought around two years ago,
The previous lovely bronze bushes I made were destroyed by my failure to clean the grit out after sand blasting. I was in a bit of a hurry so put in the pair of rubber ones I had kicking around. I just couldn't wait to get the bike back on the road. My fault
I should get a delivery of new bronze bushes today.
Posted: Tue Feb 23, 2021 3:03 pm
by Steven.Carter
I had a nervous look inside the timing cover.
Miracles of Miracles, it was ok.
Posted: Tue Feb 23, 2021 7:48 pm
by Steven.Carter
Alan got my old bushes out for me now time to give it a good clean out.
When I tried to clean it out after the sand blasting I can see how I went wrong. I should have removed the bushes, I would never have been able to get the grit out behind the bush inside the swinging arm. That shoulder would have trapped the grit.
With no bushes in it was easy to pull a rag through.
I had to take a small about off the outside dia to get it to push into the arm. Things have got a big rusty in my garage over winter
Posted: Tue Feb 23, 2021 8:57 pm
Ah! European machines rust too !
Posted: Tue Feb 23, 2021 10:57 pm
by nevhunter
Do you live near the coast? Nev
Posted: Tue Feb 23, 2021 11:22 pm
All of the Netherlands is near the sea, and where I live also about 4 meter below it !
But...all Dutch can swim
