Page 6 of 6
Re: A corner for VBs (and other sidevalves)
Posted: Sat Aug 21, 2021 9:40 pm
by garycullen
Derek, my 1946 VB valve chest vents to atmosphere. Pipe runs from a banjo fitting on the barrel down similar manner and next to the timing chain case vent. Both end at about the same level as the frame cross meter close by.
Make sure both discharge pipes are not in contact with each other ( or are tethered tightly together) or any part of the frame other wise vibration will occur?
Gary
Posted: Sun Aug 22, 2021 4:12 pm
by derekmalcolm
Thanks. That is another element I can finalise.
Posted: Sun Aug 22, 2021 9:47 pm
by garycullen
Derek, I will attempt to get a picture for you later today.
Gary
Posted: Mon Aug 23, 2021 2:06 am
by garycullen
Fist pic showing my valve chest banjo connection.
Second pic showing both Valve Chest and timing case breather pipes exiting vertically down to just below the bottom frame cross member.
The shiny horizontal pipes in the foreground are oil out and return to the engine.[attachment
Gary
Posted: Mon Aug 23, 2021 5:55 pm
by Roger Gwynn
It sort of dangles down and vents to the atmosphere.
