W/NG timing chain
alan.moore
Re: W/NG timing chain
Post by alan.moore »
Luis, Yes just use the half link, no split link. As long as you have 35 links total it will be correct length
LuisPaz
Post by LuisPaz »
The new chain ready to install
Luis, from Argentina
1944 Ariel WNG
LuisPaz
Post by LuisPaz »
Very bad gear cover...
Magdyno hole ...
1944 Ariel WNG
alan.moore
Luis, did you peen over that half link or is it just held on by the split pin?
Yes, that cover is a bit rough there should be plenty better than that around. Nev
Post by Simon.Gardiner »
Luis, if that was my timing cover I'd have stuck something on it with epoxy or even car body filler (Plastic Padding served me well in its original formula).
It may not be very 'professional' but it's quicker and easier than alloy welding (especially if you don't have access to an alloy welder) and it's a lot better than having a chunk missing.
(I've used epoxy to replace a piece of the inner face of that cover before now - where it butts up against the crankcase, that someone had knocked out with a screwdriver. That turned out to be a permanent repair!)
LuisPaz
Post by LuisPaz »
alan.moore wrote:Luis, did you peen over that half link or is it just held on by the split pin?
Hi Alan
I will use only the half link.
nevhunter wrote:Yes, that cover is a bit rough there should be plenty better than that around. Nev
Hi Nev, i looking for a cover to replace this.
It has welds and has small broken places... :cry:
Simon.Gardiner wrote:Luis, if that was my timing cover I'd have stuck something on it with epoxy or even car body filler (Plastic Padding served me well in its original formula).
Hi Simon
What good advice do you give me and gives me hope to repair if I do not find a replacement.
1944 Ariel WNG
LuisPaz
Post by LuisPaz »
Why when oil pump is running, oil comes out through the hole marked with the red arrow?
1944 Ariel WNG
adrie.degraaff
Post by adrie.degraaff »
The oil is dripping from the top through the pushrodpipes on the cam and that is coming from the hole to a level and than goes back in to the crankcase.
Yes it's only a drain hole near the lower part of the outer chaincase. That chaincase is essentially the same for a long time. The adjustable oil pressure component changed in the early W/NG period. Even an early bike could have had it replaced during servicing. There have been quite a few new ones about over the years. Surely someone has one better than that lying around spare. Nev
